7.3powerstroke00
Brownwood
Probably need to pop a fuse in.
The plug has 2 hot wires and 2 grounds, I may just have to move the prongs to the correct positions. Just need to figure out which wires need to be hot and which grounded... For my reg cab it only shows a fuse location for the driver power seat.
Betarocker
Sea to Sky, BC
You have power to the connector plug? Or it appears that there are the 2 circuits?
mandkole
Northwest
A few quarts of delo, a filter, inspected the spacers/brakes/coolant and tire rotation. Found a small front pass side axle seal leak, grrr.
switched the 6.7 over to LE monolec 5w40.. instantly smoother running..
01pwrstkr
Polk County NC
or air in the system...
Whoops forgot about air
I need to order some LE and give it a try
Sent from my SM-N920R4 using Tapatalk
every LE product that I have used performs better then expected.. only thing I didn't notice was diff fluid.. that isn't really something you can feel or hear, except when put in the transmissions of a couple log trucks. smooth shifting. like a trans with over a quarter million miles feels new again..
fuel additive, trans fluid, motor oil, gear/diff oil, grease... they are some amazing products!!
01pwrstkr
Polk County NC
My next service is after the holidays. I'll give it a try. Did you get it from jimdawg on here? Or order from online?
jimdawg185 all the way.. everything I listed i get for maintenance at work. it's good chit! the grease is hands down the best chit ever used..
01pwrstkr
Polk County NC
Cool deal! Thanks man!
