Formally BTS/FFD Dual Hpop
ncollins64
winchester springs, tn
I'm going to sell my FFD dual hpop kit for the 7.3. It was one of our first units we released. Only reason i'm selling is because i'm never going bigger than stage 1s, so ill pass this on to someone that can use it. I absolutely love the kit, and something I've noticed is it drives like stock and builds boost quicker in between gears than it did in stock form. Has awesome street manners and will support any injector you throw at it. The whole setup has about 4500 miles on it and has a new motorcraft ipr, and comes with all lines, harness, and fittings needed for install. Ill also get you instructions. I WILL NOT need a core for the top pump. Retail is $1850 plus a $250 core. Ill sell this kit for $1650 shipped. Ill get pics up asap or you can txt and ill get some sent over. 931-308-109seven. Thanks
dammit.. this is the second set of duals for sale that I will eventually need and can't get..
glws man!
ncollins64
Pic
Here's one pic I took while on the truck. It's dirty here but it's polished up and cleaned now.
ncollins64
Pic
And heres another. When I get back to the shop I'll get a pic of the seperate pieces all cleaned up in the box
ncollins64
We have a aluminum block in between the front cover and resi, that's where the top pump mounts. It's a stacked design so 2 pumps isn't hanging off the back of each other putting stress on the small mounting bolts.
What about the reverse rotation?
that is the difference in the dual setups. bts is stacked, termies are inline and swamps gen 3 just adds a halidex hydraulic pump to the standard hpop..
Your fine. Since we're not a vendor at the moment I can't go into detail on that part, there made for us.
yeah, that's where the formerly part comes in but most everyone knows who started it..
ncollins64
Yea Ryan with full force bought the patent from Brian some time back. I need to just pay and have FFD setup again on here. I'll do $1550 shipped, no core needed
PABowhunter
So tempting. This works with your existing hpop in place and just adds the reverse rotation pump on top correct?
