Coolant overflow bubbling in degas
KAquack
Alabama
My coolant has over flowed before. When I turn the truck off my coolant bubles in the bottle. The truck have been studded and has an mishimoto rad. It also has a coolant filtration system. I know this problem can be caused by an Kim head gasket or the head being lifted under boost pressure. My eot and etc run around the 185-195 range usually 4-6* apart. The only time I can get the system to Puke is going up the mountains close to my house runythw boost around 20psi for a period of time or to hit 35+ lbs of boost. Any one have an idea or input of what my problem could be?
Lipka101
Maryland
Head gaskets. Possibly egr cooler leaking if they still on the truck.
KAquack
Alabama
im pretty sure the head gasket is blown too. The truck is supposed to be studded but i guess not
Lipka101
Maryland
If the heads were warped or damaged it could be leaking even if it is studded. Maybe the block wasn't prepped properly.
Sideswipe505
New Mexico
This. 6.4s are notorious for head problems unfortunately. I'd say more often than not, heads need to be worked on if they lift.
kjk427
Is the Degas bottle the correct one for the 6.4 ?
The attachments show the what the incorrect and correct bottle should look like and the updated Venturi T for the degas bottle.
If all this is correct have you replaced the stock degas bottle cap with a replacement cap?
The stock cap is prone to failing and not holding the correct pressure inside the degas bottle, you can pick up a replacement cap at any autoparts store.
silatj
What he said. I noticed a coolant leak two days ago. Changed my cap and all good. Second time I've changed the cap
KAquack
Alabama
my degas bottle has the two hose style. the top hose is caped and I do not need the Venturi t due to me not having an egr
