DarcyB
I've been doing some research and reading on some different forums and Google searching but can't find exact answers to my questions. Looking for input from the guys using their trucks for towing and hauling. I've read that a lot of guys are liking the carli lifts and icon lift for smooth ride and comfort. Myself I'm not too big on needing a more comfortable ride and wanna retain the trucks capacity without a squatting rear when a trailers loaded and attached. I've read that this is a problem using the carli system with full leaf pack replacement, not sure if that's for all systems though. Other research I've come across is with rear block lift kits though, the bigger the lift block the worse axle wrap occurs so traction bars are required.
I'm looking to get the clearance for the 22" 10 lug "super singles" with adapters and 35" tires. Similar to these trucks.
My truck is a 2015 F250 super cab long box. Has the 2 piece drive shaft and overload springs in the rear with the +3" blocks. Also has the rear sway bar.
My lift options I'm looking at are priced around the $2500 mark, here are links to the options I'm looking at. Some include traction bars which I want with blocks and some include extended brake lines which I'm not sure if are a necessity. Any help would be appreciated.
4" BDS $2367.33
http://bds-suspension.com/kit-customizer?kid=588H
Included in kit build:
Progressive Coils
Radius arm drop brackets
Sway bar drop brackets
Dropped pitman arm
Track bar relocation bracket
Bump stop extensions
5" rear blocks
NX2 series shocks
Rear dual add-a-leaf
Recoil traction bars
Drive shaft alignment kit
4.5" PMF Alpha Kit $2779.00
http://www.pmfsuspension.com/2011-16-45-Alpha_p_84.html
Includes:
Progressive coils
Adjustable 3-link arms
Stage 2 traction bars
6" rear blocks
5/8" U-bolt kit
Bilstein 5100 series shocks
Adjustable track bar
4" Pure Performance Triple Threat Stage 1 $2649.00
http://www.pure-performance.biz/11-Pres-F250-4-Triple-Threat-Stage1-p/2410009.htm
Includes:
Sport tuned progressive front coils
Sway bar end links
Rear mini spring packs
Rear blocks
Extended brake lines
Sport tuned 2.0 prodigy shocks
U-bolt kit
4" Pure Performance x-factor stage 2 $2649.00
http://www.pure-performance.biz/11-Pres-F250-4-X-Factor-Stage2-p/2420015.htm
Includes:
Sport tuned progressive rate coils
Adjustable Trac bar
Sway bar end links
Lift blocks
U-bolt kit
Sport tuned 2.625 prodigy shocks
4.5" Carli starter system $2695.00
http://www.carlisuspension.com/ford-super-duty/suspension/starter.html
Includes:
Carli multi rate coils
Radius arm drop brackets with cross member
Sway bar end links
6 leaf progressive add-a-packs
Bump stop drops
4" Cognito Stage 3 Tow Pkg. $2167.90
http://www.xtremediesel.com/Cognito...e-3-Tow-Pkg.-4-Lift-with-Bilstein-Shocks.aspx
Includes:
Progressive rate coils
Boxed radius arms
Track bar bracket
Drop pitman arm
4.5" rear blocks
4.5" icon stage 1 system $2325.23
http://iconvehicledynamics.com/shop...ty-f250-f350-45-suspension-system-stage1.html
Includes:
Bump stop spacers
Brake line brackets
Dual rate coils
5" rear blocks
U-bolt kit
Icon 2.0 shocks
Sent from my SGH-I337M using Tapatalk
4" BDS $2367.33
Progressive Coils
Dropped pitman arm
5" rear blocks
NX2 series shocks
Includes:
Progressive coils
6" rear blocks
5/8" U-bolt kit
Includes:
Sway bar end links
Rear blocks
U-bolt kit
Includes:
Adjustable Trac bar
Sway bar end links
Lift blocks
U-bolt kit
Includes:
Sway bar end links
Bump stop drops
Includes:
Boxed radius arms
Track bar bracket
Drop pitman arm
4.5" rear blocks
Includes:
Bump stop spacers
Brake line brackets
Dual rate coils
5" rear blocks
U-bolt kit
Icon 2.0 shocks
