Anyone with a 6" lift running 22x14 wheels on 37s???
mchico
Hey everyone ......anyone use a 6" suspension lift running 22x14s on 37s or a similar setup on a '17
Jmuck
look up Jmuck thread on here.
This is with a 2" front level kit, 37's on 22x10's.
The white one I built has a 6" Pro Comp with 37's and 20's. It measured right 5" over stock height with waaay too much rake IMO.
mchico
The trucks look good !! Hard to tell the rake in the pic jmuck. I was thinking of using a pro comp 6" as well, will adjustable front shocks be the solution to level out the rake? (My first superduty sorry for the questions ) I know 22x12s with 37s fit just wondering about 14s. thx for the pics
Jmuck
Only solution to the rake is a smaller rear block, and or front level kit/taller spring.
mchico
can I stack front level on top of the kit ? Where do I get a taller spring ....seen pro comp offers a 8" kit as well, guess taller spring and larger rear block
Jmuck
You'll need an adjustable trac bar if you add a level kit and or taller spring.
