Anyone run these intercooler pipes?
JRLott
TX
Thanks, Nathaniel. I was hoping I wouldn't have to call out of my own curiosity.
looks to connect in the exact same way as the factory flange does too
More dumb questions real quick, does the oem vs d eleted ic pipe upgrades have any advantages?
i.e.
Is this kit in someway stronger?
https://hs-motorsports.com/11-16-ford-6-7l-intercooler-upgrade-kit.html
Than this?
https://hs-motorsports.com/11-16-ford-6-7l-intercooler-upgrade-kit-oem.html
the first one is the throttle dereet that requires weight loss tuning and the other is a upgrade for the stock guys..
TRUBBS
Balls Deep
I ordered my set last week after blowing the stock one for the 6th or 7th time.
seams to be a 100% stock replacement just with better boots and aluminum pipe over the garbage plastic, shipping is kind of slow tho, ordered the 27th and wont be here untill the 6th. Should have checked on amazon first instead of Ebay and took advantage of my Prime....
Hindsight is 20/20 right?
