Dual disc ceramic button clutch 7.3/zf6
mikeeg02
Drifting, PA
Dual disc ceramic button clutch, just got back from Kentucky clutch. I Upgraded to a sintered iron, and bought a whole replacement to help eliminate downtime. Setup for a 7.3 with a zf6. Everything you need (pressure plate, discs, floater, flywheel) aside from the bolts to the crankshaft, they aren't provided. $1,100 shipped to the lower 48.
mikeeg02
Drifting, PA
Pictures attached. See fresh machining. :naughty: :ford:
mikeeg02
Drifting, PA
Rated at 650 HP
I believe they replaced the pressure plate too. No marks from a table grinder, and the fingers dont have wear from a throwout bearing
this is the exact same one I have in my 01..it's a good setup for sure!!
NyCowboy87
Arkport, N.Y.
How would it be in a daily driver/tow rig? Truck is a shade over 450 and single disc clutches are not up to the task. Don't want something that is super jumpy and real grabby when I'm trying to back up with the trailer.
its kinda gabby when you are lugging it.. I found that it can be slipped easier and doesn't get all herky jerky when you Rev it up around 1200-1300rpm and ease out of the clucth.. if reverse is that bad while backing up a trailer, the is always low lock..
its a pretty stout clutch.. should be a 3800lb plate..
