Fuel system options
FL
I'm in the middle of swapping all my stock parts on my 97. I had a no start issue and narrowed it down to no fuel pressure. It hit me that this is a 2000 motor and does not have the lobe on the cam for the mech. Fuel pump.
What are my options? Ive been looking at the tightwad mod. I have a walbro fuel pump to use too. I'm Looking to go as CHEAP as possible so I can sell this truck. Can I feed the stock mech pump with the electric pump to keep the factory hard lines?
79jasper
skiatook, Oklahoma
But it's going to restrict flow.
And if the diaphragm busts it can fill the crankcase with fuel.
FL
Yea, about 5 gallons worth pretty quickly lol. Next question, will the srock FPR work with a e fuel pump?? Gonna get a Y and feed the heads.
superpsd
Missouri
If the diaphragm burst I am not sure it would bleed into the crankcase. The diaphragm is on the upper level of the pump above the high pressure side of the pump. There is two weep holes on the pump. One for the low pressure and one for the high. Other than that just ditch the pump if you have no way to cam drive it. There is a fitting that bolts up to the banjo setup to replace the pump. As for the regulator either run an adjustable regulator or be a cheap way and modify the stock regulator.
FL
If the diaphragm burst I am not sure it would bleed into the crankcase. The diaphragm is on the upper level of the pump above the high pressure side of the pump. Other than that just ditch the pump if you have no way to cam drive it. There is a fitting that bolts up to the banjo setup to replace the pump. As for the regulator either run an adjustable regulator or be a cheap way and modify the stock regulator.
It filled my crankcase. Where do I get that fitting they bolts to the banjo? Also, I already modded to stick regulator so I'm gonna use that if it'll work.
superpsd
Missouri
The high pressure piston side does have a seal at the tappet that can blow. My pump just weeped out the weep holes and drained thru the valley drain hole. Found a picture of the fitting adapters.
superpsd
Missouri
I think a few vendors sell the fittings. They charge a ridiculous amount I see. I will not post them up since they are not vendors here. You will have to search. If you figure out the fitting sizes I bet you could buy them for under 10$. I think this is the part number for the banjo bolt adapter. #6404-12-08
haligen
I just bought mine off Amazon. 2 day prime for $13. Don't forget new crush washers.
FL
Ended up using the 3/4" boss fitting and keeping the hard lines. I have about 70$ in this E fuel system. Had an old walbro pump and used the stock FPR.
jvc1990
Blaine,Ky
gnxtc2,do you recall what type & size fittings you used to splice onto the factory supply & return fuel lines?it makes sence to use the factory fuel lines.beacuse some of these fuel kits you buy use a 3/8 supply & 5/16 return hose.which looks close to the factory fuel lines.thanks
haligen
I'm not gnxtc2 but I used a 5/16 compression to -6 an on the feed from the pump and 3/8 to -6 an on the engine. Return was just a barbed fitting to 5/16 hose with fuel injection clamps. From the tank I used the original rubber supply line from the selector switch to a 3/8 barb with clamp.
freddie
Ohio
How's it working for you? Found a 97 7.3 for sale for the right price, claims that the factory fuel pump is leaking. Thinking about getting it for my dad and doing the cheapest Efuel system I can.
FL
Runs really good actually. Better than it did with the mech pump.
