Black Magnum 2.0 assembly
Magnum PD
VA
I ohmed out the injector that doesn't have oil coming from it and showed 2.8. Too low?
Magnum PD
VA
I'm just gonna have to send all the sticks to Tim to get checked out.
I ohmed out another, same thing I think.
Tim @ P.I.S.
Sunny, FL
If you have a freshly assembled engine that is only running on a stand with some idle time and no way to place a load on it then you have some air in the system.
The main question is did it run fine when you pulled them out? They will not go bad sitting on the shelf waiting for a new engine to be built.
Magnum PD
VA
Putting stuff back together. Threw some paint on. This is as good as it's gonna get. Paint won't stick to some places.
IMG_0064_zpsy3zccofn.jpg[/URL
Magnum PD
VA
Had some left over oil so, I primed the lpo and filled the HPO rails.
I'm gonna admit to put engine in with the trans still in the truck. Hope I can lift trans enough to get it matched up then slide on to engine mounts. What say y'all?
its kinda a pita by yourself.. be better to slide trans back a bit, drop motor in, then slide trans forward..
Yea. Sure is. Been there, done that, ain't goin back.
ghohouston
Lewisville,Texas
I briefly tried to pull my obs engine, and couldn't get enough clearance between the oil pan and crossmember, and clutch/input shaft/bell housing all together to get the motor out. I think it was hitting the underside of the wiper cowl too, but its been a couple months ago. I attempted it just like an auto, and put a ratchet strap under the trans bellhousing, but no go. I decided i need to get a trans jack and bring the zf5 back a few inches before trying to pull the motor.
97stoker350
south central pa
I pulled mine 3 times out the top. Have to take the clutch off and pull the trans back while dropping it down with Jack's. I used a car and motorcycle jack because I didn't have a trans jack. Mine is also an obs. Yes it can be done. Yes it sucks ass
Magnum PD
VA
Whew!
Took over 3 hours, ratchet strap, floor jack, and turned into a grease monkey but engine is back in the truck
