Update on my rig
Six_Sloww
Southeast MI
Correct. More technically, aluminum diffusion alloying. If it was actual galvanizing, it would not weld worth a sh*t.
Don't make me bust out the chemical formula and electronic diagram...
Sounds sexy, happy for everyone involved that this project is finally nearing completion. (I'm knocking on wood as I type this)
is there a hp goal you are shooting for or basically the same as it always has been but just refined a lil better?
Erikclaw
Central CA
no goal, it does what it does. May be a little higher on fuel now since its on 125% injectors and a 64 non vgt. Ill probably spray it on the dyno just to do it but that's it.
badass! it will be a fun ride regardless!! can't wait to see more vids of it!
Black AOD
Ohio
Soooo....Built motor, I'm sure with every option possible. Fully Built 5R I'm guessing with every option. 6466 Precision into an 8891 Precision with Twin Pumps and 125%'s....with Hood stack. F*kin Rowdy is what this thing is now.
when you put it that way, dam straight it is!!!😨😨😨
Administrator
this thing will be waiting to smack you down in phoenix , and then hit the local hopper events in the greater phoenix area LOL
