Just contact Mike at No Limit (bigrpwr) I believe is his screen name on here. He will give you all the options you need with excellent customer service as well.
Is it better to remove egr junk?
Sent from my SM-N910V using Tapatalk
Should he k o'clock out the intercooler pipe as well?
What else is there to make these things 100% solid?
U certainly do use your truck! Yes I've had him keep ontop of maintenance, just not on the intervals you have. Might have to tighten some up.Yes for sure. Also cleans up the engine bay.
The BEST thing to keep these reliable is maintain them. Keep up on oil, coolants, fuel filters etc.
I have 110k miles on my 2015 and I use it... some people say I abuse it, but honestly running these trucks hard don't hurt them IMO. I have my intervals way less then what ford recommends.
Engine oil 10k miles (LE fill syn oil)
Trans (drain every 10k with LE trans oil)
Fuel filters 10k miles
Air filter 10k miles
Coolant 36k miles
Brake fluid 36k miles or once a year
Rear diff oil 20k miles
Front diff 20-40k miles
Transfer case 20k miles
PS fluid 20k miles (I just suck it out with a syringe as much as. I can so I don't have to bleed it)
Maintaining the truck is #1, I'm anal though, I even keep every fuel receipt and every one is numbered, I'm currently at receipt #550.
What's reason for this? Stock one fail?Yes, he should get a H&S Intercooler pipe upgrade for sure.
OK cool.... had same problem with my 6.0 [emoji52]It's plastic!!!! Upgrade and don't look back.
Anything else to make these as reliable as possible? After pulling our new trailer with the 6.blow I'm disappointed in both power and the "driving on eggshell" feeling, especially with the little ones in the truck, so I'm thinking about upgrading at some point.
You're disappointed on how your 2015 6.7 towed?!?
2005 6.0 - all stock
