noise
BigBluediesel08
Laredo,Tx
Did the egr cooler delete last week..Started hearing a screeching sound next to the fuel cooler reservior. im sure everything is connected. Truck runs fine. Did i miss something? Dont wana damage something.
Heavyhaul
Wyoming
My buddy's truck had a screeching when the turbo would start to spool. Found a exh leak on the drivers side manifold.
BigBluediesel08
Laredo,Tx
Sound like its coming from right next of the fuel cooler resorvior.. Two lines plug into it, silver box. Dont member wat is called.
greasltn
Hillsborough, NC
Did you move the EBP sensor, if you didn't get the bung welded in good enough it will make that sound. If you didn't get the up pipes bolted properly they will also make that noise.
BFT
southern cali
you dont have to remove any of that stuff on a EGR cooler delete.
