Parts needed for 2015+ turbo swap
Phiber Optik
Victoria BC
Ok so I got a 2015 turbo and a bunch of factory parts, does anyone know of a complete list of parts needed to swap the 2015 turbo onto a 2012 6.7? I've watched a few how to 2011-2014 turbo removal videos on YouTube but no 2015 upgrade videos found yet...
Thanks
This list applies to parts for a 15-16 model year only. 17+ turbo & pedestal are different as well as you don't need the oil tube. This list doesnt include hardware so don't break any bolts lol.
FC3Z6K682A – Turbo
FC3Z9T514A – Gasket Kit
FC3Z6N639A – Pedestal
FC3Z9G437B – Exhaust Pipe (Right)
FC3Z9G437C – Exhaust Pipe (Left)
FC3Z6N646C – Down Pipe
FC3Z8287A – Pipe Clamp
FC3Z9B613A – Inlet Hose
FC3Z6B689A – Oil Tube
FC3Z9U469A – Water Outlet tube
FC3Z9430B – Manifold (Right)
FC3Z9424A – Inlet Manifold Assembly
FC3Z9448A – Gasket (Right)
FC3Z9448A – Gasket (Left)
FC3Z9A462A – Heat Shield
FC3Z9E464A – Gasket
BC3Z9E464B – EGR Connector Tube Gasket
wjamesm
Bellefonte pa.
This is the list i found over at .org
FC3Z6K682A – Turbo - - - $1323.18
FC3Z9T514A – Gasket Kit - - - $42.28
FC3Z6N639A – Pedestal - - - $50.86
FC3Z9G437B – Exhaust Pipe (Right) - - - $14.52
FC3Z9G437C – Exhaust Pipe (Left) - - - $11.52
FC3Z6N646C – Down Pipe - - - $59.69
FC3Z8287A – Pipe Clamp - - - $12.55
FC3Z9B613A – Inlet Hose - - - $13.96
FC3Z6B689A – Oil Tube - - - $23.56
FC3Z9U469A – Water Outlet tube - - - $27.53
FC3Z9430B – Manifold (Right) - - - $50.62
FC3Z9424A – Inlet Manifold Assembly - - - $104.89
FC3Z9448A – Gasket (Right) - - - $9.62
FC3Z9448A – Gasket (Left) - - - $9.62
FC3Z9A462A – Heat Shield - - - $9.34
FC3Z9E464A – Gasket - - - $4.27
FC3Z9F459A – Tube EGR Valve - - - $32.70
FC3Z6N646A – Exhaust Pipe - - - $112.70
BC3Z9E464B – EGR Connector Tube Gasket - - - $3.06
Total online price $1916.47
Identical to my list....minus the two parts I excluded as they aren't needed....
NCSU dirt man
Ft. Bragg, NC
just out of curiosity where do yall shop online for OEM Ford parts at prices that cheap? the local stealership is alot higher but i wasn't sure which online OEM Ford parts place to trust
WhiteMamba_Scorpion
I'm guessing Sunrise Ford in the vendor section. You get a discount for being a PSA Member.
wjamesm
Bellefonte pa.
Yep the prices in my post were suppose to be from Sunrise Ford . They were quoted awhile ago so they are probably alittle more now than what was listed in my post .
aftermarket. I couldn't find a way to read the factory one.
I was always told the H&S monitor can use the factory probe? I had an edge so I went with their egt probe.
I would love to know how...where do i get a harness to connect to the factory probe? And how does that harness connect to the H&S?
Dont forget, 14 and down dont have a factory probe in that position...
i'm guessing you used an adapter to go from the im guessing m14 thread to the female 1/8" npt
correct.
