To CCV mod or not to CCV mod, that is the question
95cobby
Houston
Not to be rude, or come off the wrong way..... but when modding these trucks..... some times you have to think outside the box.......
Sorry your having an issue.... wish you weren't, and as far as No Limit Fab and their custom parts and customer support..... you won't find any better guys!
All I do is call and ask for Luke or Jeff, tell them is **** from Louisiana.... and bam! They know the truck, know what I'm wanting to do, heck..... they have got Mr. Mike involved a time or two..... great guys, great shop
Nah it's all good. But when I asked where the valve should be placed that's the spot I was told. I suggested before the smaller 20" piece but I did as told and now I'm in this dilemma.
I've bought all my stuff from No Limit and will continue to do so. I've had a great experience with them despite a few things that happened recently that don't need to be discussed here.
Anyways, I'm working with Mike to get this resolved.
And your video... that's what I expected but I got just the opposite. I have myself a ballon maker.
kcpanages
I hear ya
As an Amazon Associate we earn from qualifying purchases.
Mesa, AZ
Aside from where it is made. How does the design compare to others?
Im running the stainless version on my 6.0, seems to work fine. Only thing that was kind of a pain in the ass was lining the cut up when screwing it into the welded in portion. I marked the top and screwed it in, it was not fully screwed down if i remember right.
black'n'blue
Is the catch can necessary? And if not, I understand the concept of it, but why?
Sent from my LG-H871 using Tapatalk
JetExpress_6.7
Not necessary at all. Mine's open to atmosphere right under the front fender, although I did leave the factory box in place to let it do its job. Kind of a catch can in itself, never understood the point of everyone taking those off to install an aftermarket can underneath the truck again...
black'n'blue
My understanding of it was that the filter media inside the doghouse became saturated causing higher than normal internal pressure in the cc. Mine is vented to atmo but I wanted to plumb it into the exhaust minus the catch can unless it was necessary somehow in the "venturi" effect
kcpanages
Yes, it WILL become saturated..... it's easier Maintenance to remove the system, and install the reroute.... which will allow you to drain off the oil out of the catch can when you do an oil change........
kcpanages
Venturi with the No Limit Fab catch can
