powerstroker66
Just wrapping this truck up and noticed i do not have any brake lights. However, i do have turn signals, flashers, reverse lights etc. The switch has power coming into it and out of it with the pedal depressed. Meters out ohm wise fine too. From research i found that if i dont have turn signals its a bad multi switch since the brake pedal switch impulse goes through the multi switch but that is not the case so i am stumped. My only other thought is a bad clock spring/wrong year column. The column appears to be a 99-01 column and does have a bad clock spring. Could that be the under lieing issue? Thanks all!
