Ouo traction bars
Poglife
Georgia
So I bought me some ouo traction bars for my 04 and ended up selling it before I put them on I was wondering if the front frame bracket and the rear traction block I bought will fit the 15. Brain says yes but want to make sure before I start. Thanks guys
Swampfox
TN
What is the part # on them? Mine are 45001 and 45002 on the mounts. Also the width of the leaf spring could be different, mine is a 2016 and they are 3" wide. My 2006 f350 work truck has 3" wide springs to so you might be ok.
Layson
I know they are pretty good about swapping parts out to make it work. Front mount should be the same the rear I am not sure. Give Jared a call and ask him. He should be able to help you out.
Breaking Habits
Mapleton, Illinois
The only thing that would worry me is putting a 0* block into a truck that needs at least a 2.5* Taper.
Give me a shout and let me know what you've got going on
503-780-3818 - Jared
Poglife
Georgia
How do I know if I need a taper I believe my rear blocks are just 3.75" or whatever the smallest one is .. figured front mount is the same thanks .
