Fully Built 7.3 Engine
Obsledpuller
Gibbsboro
I'm Tossing around swap ideas and want to gauge interest on my engine and go fast goodies.
3/4 Fill BlockGirdle
R+R RodsCustom .020 over pistons coated
Fire-ringed head/blockStage 2
Gear**** stage 2 Cam
Heads were hand ported
Studs, Pushrods, Springs
Full Force 450/400's
BTS Dual pump setup over adrenaline HPOP
Lewis Built Aluminum Valve covers
Fluidampr
PI Billet Flexplate
Truck went a best of [email protected] on June 10, 2017
If there isn't enough interest as a whole I will consider parting it but I will not remove it until the long block is sold
12,500
Obsledpuller
Gibbsboro
How many miles on the setup?
The HPOPs are the only thing not replaced when I put the engine in it has about 150 miles ago this truck has been almost all track use(drove to track a few times). Put it in the end of the season before last so roughly a season and a half of racing on it.
DocBar
Akron, Ohio
Fluidampr
PI Billet Flexplate
12,500
No turbo to go with it? What turbo set up were you running ?
Obsledpuller
Gibbsboro
Who built the motor?
Any idea what you would want for the long block?
Carson StaufFer Built the motor.
I Was running a 476/96 and it loved that turbo only problem was the smoke of the 450's lol
I'm thinking around $9500 for the long block if I split it up
DieselDC
Are partial filled blocks okay to DD? I though partially filled blocks are for big ponies? Like for sled pulling/track only kinda deal?
79jasper
skiatook, Oklahoma
That's the purpose of a partial fill, so you still have some cooling.
I can't give you names, but there were people dd'ing them.
Sent from my SM-G892A using Tapatalk
DieselDC
O "some cooling" haha yeah that about answered all I need to know. Thanks
Obsledpuller
Gibbsboro
I've never had a cooling issue with this truck. You can 3/4 fill a 7.3 (if done correctly) you won't have any cooling issue as the heat build up in these engines happens prodominantly in the top 2" of the cylinder.
The passages have to be predetermined so coolant can still reach the oil cooler and such.
I know of plenty of people who were able to DD a 3/4 filled block with no issues.
Now if you get into towing a large gross for an extended period i can't speak on that.
DieselDC
So much power did the motor make to warrant a partial fill? Not poking fun but just curious!
DieselDC
[emoji106][emoji41][emoji851][emoji964]
Thanks I learned something new today.
