sunrisefordparts
I need to do the turbo swap and need the following parts
FC3Z6K682A – Turbo
FC3Z9T514A – Gasket Kit
FC3Z6N639A – Pedestal
FC3Z9G437B – Exhaust Pipe (Right)
FC3Z9G437C – Exhaust Pipe (Left)
FC3Z6N646C – Down Pipe
FC3Z8287A – Pipe Clamp
FC3Z9B613A – Inlet Hose
FC3Z6B689A – Oil Tube
FC3Z9U469A – Water Outlet tube
FC3Z9430B – Manifold (Right)
FC3Z9424A – Inlet Manifold Assembly
FC3Z9448A – Gasket (Right)
FC3Z9448A – Gasket (Left)
FC3Z9A462A – Heat Shield
FC3Z9E464A – Gasket
FC3Z9F459A – Tube EGR Valve
FC3Z6N646A – Exhaust Pipe
BC3Z9E464B – EGR Connector Tube Gasket
this would be the updated list for the turbo swap parts.
  • 15 TURBO KIT.pdf
gunmaniac3521
havelock, NC
Does that part number i gave you go to a 99-02 Lincoln navigator? I did a steering wheel swap on my excursion and that was the part number i previously used but it broke internally
sunrisefordparts
yes that part number does com up for a 99-02 navigator.
kleake
Sapulpa, OK
Pistons and rings for a 2008 F250 6.4. Also, price on complete engine. I'm getting tired of pulling the cab and am contemplating a way to have some sort of warranty.
