sunrisefordparts
Also, price on:
E3TZ-4730-A
EOTZ-4730-A
Price depending on which one I buy. I believe the only difference is the bolt length. If you can confirm that, Id appreciate it.
4c2z-2c028-aa list $37.07 sell $24.47
e3tz-4730-a list $19.35 sell $13.93
eotz-4730-a list $24.23 sell $17.45
as for the difference only thing my catalog show is the e3tz is for the 250-350 and the eotz is for the 450-550 trucks
q#506648
blackseven
2011 F-350 DRW Lariat
Looking for an upfitter kit:
AL3Z-13D730-AA Switch
BC3Z-14A303-B Harness
GL3Z-10E928-AA Sirius/GPS Antenna Splitter Harness (not sure if this is the correct part number - want to use Stock GPS antenna for aftermarket radio)
BC3Z-8200-BPTM - Primed paint to match grill
AA8Z-9942528-A - Replacement tail gate badge
email is defekticon@gmail.com
Thank you!
sunrisefordparts
Thank you!
email sent.
Hoosierdaddy
Looking for F450 parts,
Recently acquired OEM front F450 flares to put on my F350, but my factory front splash guards do not match up with the indentions on the new flares at the back of the wheel well area. I can't even find a ford part number for the OEM splash guards on a Platinum F450. I need splash guards or caps, or whatever fits in these indentions at the bottom of the flares. Need part numbers or a diagram to confirm I'm chasing the right parts.
Thanks.
price on HC3Z-6K682-A also confirm that is for 17 year model wide frame. Thanks.
Mobilemedic
Can I get a quote on this part.
4C4Z-7004302-BA
F650 lower dash piece.
Thank you
Vendingtech@gmail com
Sent from my XT1650 using Tapatalk
FordPSD64
San Antonio, TX
Part numbers:
DL3Z-19A390-B
FT4Z-19A361-A
Also can you confirm that these will work on a 17 f250? It should be to add remote start via the ford pass app
Shipped to 78258
Thank you, Jeremy
sunrisefordparts
can you quote me and check availability:
1-Access Cover- YL3Z-9943121-AA
8 screws- W710734-S439
Thanks
currently the access panel is backordered with no availability of when they will be supplying a new part
yl3z-9943121-aa list $80.33 sell $57.84
w710734-s439 list $2.70 each sell $1.62 each
q#509596
sunrisefordparts
Part numbers:
DL3Z-19A390-B
FT4Z-19A361-A
Shipped to 78258
Thank you, Jeremy
yes these show to fit your truck
dl3z-19a390-b list $385.71 sell $324.00
f4tz-19a361-a (replaced by js7z-19a361-a) list $235.00 sell $197.40
q#509598
p.mcelfresh
Worthington, PA
I'm looking for prices for both front brake dust shields on a 1994 F150. Driver side part number is F4TZ2K005B. Passenger part number is F4TZ2K004B. Thank you!!
