The haze is only at cold idle and goes away when warm usually after about 5 min of idling and it's fairly clean. As for the rough idle. It's intermittent and doesn't matter wether it's in gear or not. It's about the same. The injectors are from pis if that helps at all. I bought them cause they have had nothing but good reviews from what I've read. As for data logs. I'll be able to get them but might take a few days. I don't daily drive the truck.
Well I think I should be good then I purchased my injectors around march of this year. I also replaced my hpop with one of there units. Do you guys thinks an air bubble under my icp could cause some of these issues?
So a little bit of an update. I started the truck this morning. Oil temp was 37 degrees. The truck started to romp for a bit. The truck has new injectors icp sensor and hpop. The only thing not new was the ipr. Just stuck the old one in. So I think I’m leaning toward the ipr needing replaced. Possibly a tune revision as compression checks out.
My truck acts the same. See sig for build up. I do a cold start and it hazes.
Plus my truck sits in the garage which I keep at 70*. As soon as I pull it outside, it hazes because the motor is not up to operating temps. Once the motor warms up, the haze is gone.
After the oil temps get to operating temp (200*ish), the idle is rough when I put in Park, Neutral or Drive waiting at a light.
The truck needs to be live tuned and all the issues will be fixed. The hard part is getting the truck live tuned. You made a post when the revisions were done, it got better which should answer your question that it's tuning related. Tim posted a while back on what needs to be done tuning wise to the 175/80s but didn't elaborate. Hopefully he can elaborate so we can atleast pass the info along to the tuner.
Billy T.
gnxtc2@aol.com
