WhiteMamba_Scorpion
- Joined
- Jan 10, 2014
- Messages
- 1,952
- Reaction score
- 0
Selling my truck. Ready for a new project and it needs a new home with someone who wants a reliable 766hp daily driver with potential for 1000+ with a few simple changes. Please read the entire ad below for mod list and everything that comes with the truck for $45,000 (NO TRADES). There is easily $40k invested into this truck to make it an unbreakable weekend warrior.
Truck is located in Marietta, Ohio
2012 CCSB King Ranch
83,000 miles on truck
40,000 miles on built setup
766hp
1552tq
Truck has been meticulously maintained for 83,000 miles. Built motor and trans have 40,000 miles on them and have Lubrication Engineers fluid. Truck runs and drives great and has been on many road trips to diesel events in North Carolina, Georgia, Kentucky, etc. I would not hesitate to drive this truck across the country. Everything on this truck has been built by some of the best in the industry and I have receipts for every dollar spent on the truck. This truck is garage kept all winter and only gets driven on weekends. There is a lot of untapped potential if you put bigger injectors in it. Easily a 1000+ capable truck with some more fuel. KBB for a bone stock version is 38k so 45k is not unreasonable for what's is in this truck (40k+).
Please see the parts list below.
-H&S MiniMaxx
-Custom Tuning by Morgan Primm
-2015 Long Block
-Balanced rotating assembly
-Keyholed crank
-Billet RNR Connecting Rods
-H13 Extreme Duty Taper Wall Wrist Pins
-Stage 1 Chromoly Push Rods
-ARP Head Studs
-ARP main studs
-Elite Diesel Stage 2 Valvetrain
-Valve relief cut pistons and Ceramic coated
-Gapless rings
-Ported heads by RCD
-Elite Diesel Ported intake manifold
-HS Dual Fueler Kit
-Elite Diesel Turbo Kit with 39mm Precision wastegate
-Precision 6870 CEA
-AFE 5 inch straight pipe
-No Limit EGR ****** with flow through plate
-No Limit intercooler
-No Limit intake
-No Limit polished coolant tank
-Maryland Performance Diesel CCV kit
-2015 pump in the valley
-H&S low pressure fuel pump
-New 15% Injectors
-Remote fuel cooler mounted in bed
-Elite Diesel Extreme Duty Transmission
-Mag Hytec 6r140 pan
-One Up Offroad Traction Bars
-One Up Offroad ALAs with Updated HD joint
-One Up Offroad track rod joint
-3.73 Yukon Gears
-TrueTrac rear locker
-Rigid D2xl fog lights
-Anzo U-Bar Projector headlights
-Edge CTS2 for with EAS kit for Oil pressure, fuel pressure, EBP, Boost, EGT, and back up camera
-Mag Hytec diff covers front and rear
-Carli leveling kit
-BD Diesel adjustable track bar
-Bilstein 5100s
-Platinum 20s
-Tinted Windows
-Rockford Fosgate speakers
-AMP steps
-LineX bed liner
-LED bed lighting
-Rigid D2 backup lighting
Will also come with factory EGR, *** exhaust, with wiring harness, factory 3.31 gears front and rear, factory e locker, Undercover 1 piece bed cover, spare new unused 15% injector, left over Lubrication Engineers fluid for engine/trans/diffs, spare H&S duel fueler high pressure feed line, 5" AFE exhaust axle dump, FTE resonator, Diamond Eye 5" straight through muffler, stock intake, OEM head lights and tail lights.
Sent from my Galaxy S7
766hp
1552tq
-H&S MiniMaxx
-2015 Long Block
-Keyholed crank
-ARP Head Studs
-ARP main studs
-Gapless rings
-HS Dual Fueler Kit
-Precision 6870 CEA
-No Limit intake
-New 15% Injectors
-3.73 Yukon Gears
-Carli leveling kit
-Bilstein 5100s
-Platinum 20s
-Tinted Windows
-AMP steps
-LineX bed liner
-LED bed lighting
