Complete 6.4 Engine for sale
Strokersace
Towanda, KS
Pulled from a 2008 F350 with around 160,000 miles. Has a Sinister EGR ****** kit on it.
Motor is complete with injectors, turbos, wiring harness, etc. - EVERYTHING up and down, front to back. Have no desire to part out.
Bought the truck from my Dad's company after it lost oil pressure and lost oil externally (under the truck). Was shut down immediately and towed back to the yard. It was well maintained as it was his primary work vehicle. It's never been started since. It will turn over by hand freely and without noise so it's not locked up.*
I assumed the worst and had a replacement engine ready to go instead of tearing into this one first. Once pulled, I have found ZERO visible issues with the block or exterior of the engine. I suspect that the low pressure oil pump went out, resulting in the oil leakage and pressure loss. Didn't run a compression test and don't plan to now that it's sitting on my garage floor.
I'm not tearing this one down or rebuilding it. Sold As-Is
Can be put on a pallet and shipped anywhere in lower 48.
$3,500 obo + freight
Can be picked up locally just outside of Wichita, KS.
HossDieselWorks
Broomfield, CO
Im interested in the engine. Would you handle the shipping? Whatever it is I would pay on top of the price of the engine. Shipping would be to 80020, Broomfield Colorado.
Thanks very much!
08Monster
Needing an engine, so you think the LP oil pump failed on this? Likely needing a rebuild from being ran out of oil?
Sent from my Moto Z (2) using Tapatalk
Strokersace
Towanda, KS
Yes that's what I suspect. It still had oil in the pan (albeit not much - several quarts) when I pulled the plug just before pulling the engine.
Leftthenleft
Nc
I have a friend that just bought an f250 with a bad motor. I will send him this info in the morning and see if I can’t help you clear out some space.
Strokersace
Towanda, KS
Bump. Haven't heard back from several I've given shipping quotes to.
Just an FYI, shipping rates have been averaging about $350 to the coasts.
Strokersace
Towanda, KS
TTT
Just because I extended this offer to another user on the Forum that hasn't gotten back to me, I will do:
$2,500 shipped. To the lower 48.
