Strokersace
Fully built with the exception of connecting rods and o-ringed heads. 13,000 miles since complete (December 2017). Motor is still in truck and can provide video of it running. Or if someone local, you can come drive it. This is in my personal truck and will be pulled when sold.
Runs absolutely flawless! I just can’t leave well enough alone and decided I’m going to do a 6.7 Cummins swap.
Everything was new when built with the exception of the heads and intake manifold.
Block bored .030
IH Maxxforce pistons
Flat ZERO cracked Heads - purchased on here from AirFish
New Colt stage 2 cam - purchased on here
Ported intake manifold - purchased on here
New ARP headstuds - purchased on here
Midwest pushrods
RCD springs
Mahle lifters
OEM rockers
OEM oil cooler
Midwest CCV
6.0 BD manifolds and up-pipes
New Alliant HPFP
New Ford injectors
Stainless RCD coolant lines
RCD 59/72 turbos
Stainless No Limit hot side pipe
No Limit cold side pipe and elbow
No Limit air filter setup
No Limit E G R deleete
Maybe some additional I’m forgetting
Will come with new front cover
I have well over $17k into this thing. Only ran with motorcraft oil and fuel filters. Bad parts we’re long gone before initial startup. Only ran with custom MCC Geerhead tuning on a mini maxx.
Engine will be drop-in ready. If someone is looking for a complete setup, this is it!
$13,000 and will work with buyer on shipping.
PM me or call/text at 208-316-1828
Located near Wichita Kansas.
Could deliver anywhere in Kansas, Oklahoma, or North Texas.
Block bored .030
Midwest pushrods
RCD springs
Mahle lifters
OEM rockers
OEM oil cooler
Midwest CCV
New Alliant HPFP
New Ford injectors
RCD 59/72 turbos
