Firewall pass through
eng53ine
Ohio
Is there a plug anywhere on the 11-16 trucks like there is on the early super duty’s?
depending on what gauge of wires you need, you can use the factory provided pass thru wires.
Other than that, it is quite easy to cut the little nipple off the large rubber grommet that houses the main wire harness and fish wires thru there.
eng53ine
Ohio
Thanks
Also, do yourself a favor and remove the fender liner to make life easier.
eng53ine
Ohio
The guy that installed our radios show me a big grommet, passenger side floor board. He said pull the inner fender well and it’s a straight shot to the battery as well. I snap a picture when the truck gets back from getting lettered.
