stevens6.7
So I've noticed this "popping" type of noise if I'm turning right into a driveway or sometimes around a corner. Any ideas of what it could be? Stock rancho shocks with 35" tires on stock wheels.
Could be seized axle u-joint. could be a coil spring not seated fully against the lower rest. Could be failing body mounts.
I would immediately check lug nut torque then.Would it matter the truck only has 46K miles? I feel like it started after a trip to NTB to get a tire repaired.
Also check to make sure your 4x4 hubs are unlocked.
Cab bushings have rotted out, lower section of bushing has deteriorated, bolt washer hitting frame when frame flexes.So I've noticed this "popping" type of noise if I'm turning right into a driveway or sometimes around a corner. Any ideas of what it could be? Stock rancho shocks with 35" tires on stock wheels.
Id be checking lug nuts for sure then!!!Well it seems like it's coming more from the drivers side rear as that was the tire that was taken off and repaired. The heaviest I've had in the bed was about 2 cubic yards of bank sand and I don't have a goose neck hitch either for what its' worth.
