JCart
Tan truck is acting odd, upon start up will show low oil pressure, just above the “L” on the gauge, under 3 seconds pressure to L on start. After a while will show in middle of gauge as usual. Changed out the sensor with new Factory Ford one same same....
How to check by pass in filter head?
There is one more to check as well right?
If I put a fluid filled mechanical gauge on the sensor port on top of HPOP reservoir what should be ideal readings.
Should I also check at port on filter head?
Thanks for any suggestions.
j
j
