stevens6.7
So last night my intercooler pipe boot popped, is this H&S setup still the way to go? Also if so, which one do I order? If I order the one with aftermarket tuning I guess I have to have the MCC capability on my MM?
H&S or absolute performance are both good options. You can get the one that ******s the throttle valve since you are ******d
YesI'm guessing that's the one that requires aftermarket tuning?
Yes
Works fine with dereet tuning. Thats all it needs. If stock then you cant replace the butterfly.Sorry for the stupid question, but does H&S supply it or do I have to get it from one of the other vendors?
I like the H&S I got from no limit.
Whatever you feel like. Both accomplish the same thing.Thanks Lincolnlocker! Do you prefer one of the below kits to the next?
http://nolimitfabrication.com/index.php?route=product/product&path=138_74&product_id=580
http://nolimitfabrication.com/index.php?route=product/product&path=138_74&product_id=353
Nice! Less clamps that way.I bought the solid silicone piece.
Nothing to worry about. It's cheaper.Hindsight I probably should have went with the silicone piece but I went with the other, should be here later today and install this weekend.
Gets rid of the turbulence and slight blockage pf air flow.for you guys that have done this mod already my kit is the one from rudys that keeps the butterfly is there an advantage of getting rid of it?
