ncollins64
winchester springs, tn
2006 6.0 powerstroke
Updated stand pipes and dummy plugs
Set of glow plugs
New set of harnesses for glow plugs, injectors and ficm
Oil rail seal kit both heads
2008 6.4
Trans cooler
Thanks
sunrisefordparts
Set of glow plugs
2008 6.4
Trans cooler
Thanks
Updated stand pipes and dummy plug kit: List $165.38 -- your cost $111.14
Set of glow plugs: List $17.33 -- your cost $10.96 each ($87.68 for all 8)
harness for glow plugs: L/H- List $71.60 -- your cost $49.40
R/H- List $64.05 -- your cost $44.19
injectors and ficm harness: List $286.45 -- your cost $173.31
Ford doesn't really have a seal kit for the injector rails, I can get the o'rings for the ICP and little rail plug o'rings.... figure less than $10
Q577748
thanks,
Sean
Motostroker
I need a EBP tube (or assembly) for my 2015 6.7
FC3Z-9J460
j.mo
Part Number:5C3Z-5415-AA
Part:Upper Spring Insulator
Two please.
j.mo
List $27.45 each -- your cost $18.94 each + shipping
Q579055
thanks,
Sean
Ok. I sent payment.
But also, I forgot. Can you add this before shipment and I'll send payment also.
The inner window seal belt where the door panel attaches.
I believe it's this
Belt Weather-Strip - Ford (F81Z-2521452-AA)
Qty 1 for right front door please.
sunrisefordparts
Ok. I sent payment.
I believe it's this
Hi,
what year is the truck, and is it a crew cab?
thanks,
Sean
