365/60/20 with a 3” RC lift will they fit?
SpyderX
Boaz, Alabama
I think they are a little bigger than 35/12.5/20. Will these fit without wheel spacers with my current setup? If not what size spacers you guys recommend?
I'm sure you mean 325 and no one should ever recommend wheel spacers
SpyderX
Boaz, Alabama
I'm running those on a two inch taller front spring with 20x10 pro-comp rims with -12 offset and half inch wheel spacers. It rubs a bit even without my front mudflaps on. I should really be another two inches taller.
I’m in a 2012 with 2017 20”
wheels. The driver side rubs a tad when fully turned so I think I would need spacers but I’m hearing those are bad news.
dadada
Indiana
No rubbing at all. 35x12.50-20's. 20x10 -18 offset. 2" leveling kit in front
TrickTruck
Simpsonville, SC
37" on a Icon leveling kit here. Trick is to get your offset right.
You want em sticking out ghetto fabulous w/ a bunch of offset then you need a big lift.
Mine are right even with the flairs and I get just a touch of rub on the mudflaps.
These are Ridge Grapplers in 37x12.5x22. My wheels are 22x10 w/ a -10 offset. Sticking way out is usually in the -40 range.
I want to put the 37x13.5x22 on there when I put new tires on, but I think I have to push the whole front end forward a smidge w/ a 3link kit. 13.5s also mean I can't fit it in the carwash anymore :( Probably going to cost me a bunch of mpg too.
Still want them :D
