How do you remove a Reductant Injector from exhaust system
lrsavory
Hamilton, Texas - 4S Ranch
:thumbup:I am trying to diagnosing my reductant system on a 2011 F350, 6.7L. I need to remove the injector to check it for leaks. Anyone know where I can find instructions??
Mesa, AZ
[emoji106]I am trying to diagnosing my reductant system on a 2011 F350, 6.7L. I need to remove the injector to check it for leaks. Anyone know where I can find instructions??
Its got 2 13mm nuts holding it on. The line has locking tabs, push the line in, squeeze the tabs, and pull the line off. There should be a locking tab on the connector you have to slide back, then press on the tab on the connectir and pull off.
