Dual pumps
2000wa250
How worth it is a dual pump system? I'm looking at a used terminator dual pump system and trying to decide if its worth it. I will be putting 250/200s in in the next couple of weeks so any opinions would be great. Thanks guys
Sent from my Droid using Tapatalk
Big Bore
9000ft in the CO Rockies
Worth it is relative to cost lol. Are the pumps worth owning? Yes. I'm assuming since they are used you are getting a good price. First thing I would do is send them to Joey and make sure they have all the updates and have them flow checked to make sure the pumps are good.
2000wa250
Yea that is my plan. I guess by worth it I mean are dual pumps still worth the extra coin (even if it isn't too much more) over some of the new singles
sent from my busted touch screen
Big Bore
Depends what size injectors you are planning to run, but twins will always flow more than a single other than maybe the big Stealths.
2000wa250
thats exactly the information I was looking for. Pretty sure I'm gonna shift some things around so i can make this happen
bruce
Middle east
Those are the injectors I'll be running and that is definitely twin pump territory IMO.
647hp 2980 psi at 38% dc are the srp1 numbers with 300/200, when it gets re released its supposed to have a lifetime warrarty and without all the hassle of duals all for 1g. hard to beat
Homesteader
What more hassle does duals give you? More hoses, etc? I would like to know what everyone talking about when they say more hassles.
Thanks
bruce
Middle east
less possiblitys of leaks, less weight hangin off the mountin bolts, and its alot cheaper than most duals
moose99psd
sunny central oregon
ever installed a set of twins? thats hassle enough, especially with a stock fuel bowl... but yes there known to rip the threads out of the front cover, more crap down in the valley if you have issues... love the pressure of twins, hate dealing with anything in my engine bay around them.
907DAVE
AK
Same could be said for twin turbo's....but no one bitches about how much power you can make with em......
;D
Homesteader
No I have not installed a set of twins yet,but if I do the motor will be on a stand when it first goes in. Fuel bowl will aslo be deleted. Ive talked to Joey about the bolt issues also. I dont mind the work. But it does look a little cramp in there, when I looked at someones Twins.
