Stealth Level 2, Turbo, Water/Meth, ETC For Sale
Twisted Excursion
Our diesel tech has sold some of his stuff but has come down on his prices since the baby's due date is getting closer. Everything is off of a 2002 F-350 7.3. He pulled with it twice at the beginning of the season and parked it to get the injectors cut out bigger.
1) HPOP: Single Stealth Level 2 with IPR, 500 miles, works perfect- $1,300 plus shipping and good core.
2) Turbo: Garret 4202R Frame, Precision 71mm billet wheel and Precision compressor housing, -4 oil feed fitting, oil drain fitting, water fittings, 5"-4" boot with clamps, water cooling lines and setup for 7.3 (taps into heater core line), 500 miles, doesn't leak oil or have any shaft play, custom made to Elite Diesel's Specs- $1,750 plus shipping
3) Water/Meth Kit: Brand new in box, Snow Performance Universal level 2 kit, with 7 gal bed resivoir kit in box- $350 plus shipping
4) Tractor Weights: 11-100lb John Deere suitcase weights painted black- $550 plus shipping
5) Weight Rack:[/B] Built for Super Duty, 2" recievers that bolt to the frame, will hold 1,100 lbs solid downthe track, no modifications except removing factory towhooks and drilling one hole per side- $300 plus shipping
Twisted Excursion
Can u PM me your cell number so i can just text you pictures of weights that will be easier for him..
Twisted Excursion
Tractor Weights are sold.
HPOP may be sold.
Water Meth may be sold.
Still have Turbo and Weight Rack to go...........
