Cazador
2011 f350 6.7 fx4
Need to do an oil change
And I haven’t replaced the belt ever so I should get one
An I get a quote for oil filter oil and belt
Thanks Sean
sunrisefordparts
2011 f350 6.7 fx4
Thanks Sean
Hi,
oil filter: $14.75 ($24.38 retail)
oil: $24.02 for each 5qt jug, you will need 3.. ($29.12 retail)
belt: $88.43 ($146.16 retail)
thanks,
Sean
q659848
kleake
Sapulpa, OK
Hi,
6C3Z-5598-A ; $29.77 each ($45.10 retail)
shipped to 74066: $20.76
thanks,
Sean
q659573
Have these shipped? If not, hold off just a second.
These are the PN for a 2016 F250 2" rear spring block. I have a 2019 with a 3-1/4" block but I am wanting to lower it by using these blocks (they have a slightly different tab for the bump stop). I am now finding that that 2021 also uses a 2" block, but I can't find a valid part number for those. I'm curious if the tab on the 2021 is the same as a 2019, or if they went back to the same as the 2016. Since I have airbags, this would save me from modifying my mount if it's the same as I currently have.
I'm hoping you have a valid part number, measurement, and picture for the 2021 spring blocks?
sunrisefordparts
Hi,
I am not showing an order for the 6C3Z-5598-A, just the quote, so nothing has been shipped. As far as the 2021 blocks, the catalog just gives me a generic illustration and about 10 different part numbers depending on wheelbase, engine size, and various appearance packages. It does not list them by size unfortunately....
sorry,
Sean
kleake
Sapulpa, OK
Hi,
sorry,
Sean
hmmm, I sent payment to your [email protected] with the quote number, if you can check on that.
Can you pull a part number for a 2021 F250 KR, and maybe a 2021 XLT, all crew cab, short bed, 6.7L? I don't know if you have any in stock, but if so could you get me a pic of one? If not just list the PN's and I'll do the research. I'm hoping to find one 1.5"-2" tall with the same shape of tab as on the 2019 3-1/4" block.
sunrisefordparts
Can you PM your email address, I can search paypal for it that way. Also I will email you the various part numbers and descriptions for the 2021 blocks. The way they are in the catalog you pretty much have to have a VIN number to determine what is what...
Cazador
Hey Sean
Looking for the driver side manifold for a 2015 f350 6.2l thanks
Cazador
Also need a throttle body
2015 f150 3.5 eco boost
Thanks Sean
Cazador
Can I get a quote
2014 f250 super duty
Front bumper
Black standard grill
Radiator
Thanks
