price and availability on LC3Z-13A576-G
Also, can the wire harness be purchased on its own? Instead of buying the whole kit with plug and mounting bezel?
sunrisefordparts
Looks like it is only available as the assembly...
I am showing it has been replaced by LC3Z-13A576-H, your cost: $111.86 ($169.48 retail) + shipping
thanks,
Sean
q669343
ford_trck
Vail, AZ
pump to booster: $41.77 ($69.04 retail)
booster to reservoir: $73.03 ($120.71 retail)
booster to gear prod date before 7/19/99: $181.50 ($300.00 retail)
gear to cooler & pump to cooler (dual hose) $170.50 ($281.82 retail) currently on back order...
thanks,
Sean
Q668656
May I get the top two hoses. I won’t bother with the other two especially since the one is back ordered.
Email. [email protected]
GatorBaitR6
Gray, TN
Your cost is $385.00 ($636.36 retail) + shipping...
if it has never been replaced, it will require an updated harness as well..
your cost $70.09 ($106.20 retail)
thanks,
Sean
q670163
Is the updated harness because of the d e l e t e d heater? Can you use your old harness and tie off the unused heater plug?
Gearzz
1ftfx1cf5bfc31570 I am also going need a quote for a short block for the same vehicle
Thanks
