psduser1
Sounds like the wrong size orings first time around, maybe. Mm/sae can be quite close, especially in the smaller sizes.
Brown vs black usually is a material difference in the oring, probably no big deal.
The smaller oring is the pressurized oil, the larger hole is the return. If the smaller oring wasn't the correct size, that would be your leak.
Keep an eye on it for several heat cycles.
