Exhaust popping noise
Joshf250
I’m going to compression test tomorrow and see what I come up with, like you guys stated I’m pretty positive it’s got a bad exhaust valve. What kind of damage do you usually find?
webb06
Seneca, MO
For sure cracked valve. I’d recommend replacing both heads. But you could probably get away with doing a valve job and replacing all exhaust valves if cost is an issue.
Joshf250
Tiha
Like the 6.4s. I'm not seeing many of these engines make it passed 200k without a catastrophic failure(not including fuel system)
Hope that is not the case, my 2014 is at 185K now.
So far I have had some aftertreatment issues, but thermostat housing leak is the only other thing it has gotten fixed.
Oh, it blew a cooler boot off one day it is still running with a cheapo hose clamp on it.
Trans acts funny but keeps hanging in there.
Joshf250
Cracked exhaust valves were the cause of the popping noise.
Joshf250
It’s free of all restrictions, and has been for a long time. The guy who owns the truck doesn’t run it hard either.
