dsberman94
Pennsylvania
Looking for availability on part # AE8T-19C107-AK. Took that number directly off a radio for a 2013 fiesta radio unit. I can’t find anything for it. Thanks
sunrisefordparts
Hi,
Your cost would be $225.23 + $500 core charge. For these, we have to submit an order through Ford Electronics, I would need the VIN number, current mileage and description of whatever is wrong with the existing radio....
thanks,
Sean
q753662
dsberman94
Pennsylvania
Hi,
thanks,
Sean
q753662
Ok, thanks. Have a couple more repair techniques I’m going to try first and might end up looking into aftermarket for the niece before going back with OE but I’ll
Let you know. Thanks again.
StokiNDieSel
Hello, 2019 F350 Drw 1ft8w3dtokeg66725.
-Looking for (F550) 6K lbs coil springs, F81A-5310-AED?
-passenger front quarter panel, painted two tone available?
-Shipped to 32732.
Thanks
sunrisefordparts
-Looking for (F550) 6K lbs coil springs: 5C3Z-5310-CA $100.10 each ($151.67 retail)
Shipped to 32732. $64.46
not sure what you need on this one.. are you looking for for the sheet metal for the bed? if so, we do not ship sheet metal, it never makes it to the destination undamaged. sorry
Cazador
Hello Sean
Looking for for a Spare tire lock and key for a 2011 f350
I’ve never used it a now lost
I need to remove the spare
sunrisefordparts
Hello Sean
Hi,
Unfortunately, the only way we can determine which key it takes is to have the truck here and go through our master set to see which one fits. If the kit was registered you might be able to get it by calling McGard at (714)662-6980
thanks,
Sean
Cazador
Hi,
thanks,
Sean
Ok I’ll try that I will stop by next week
sunrisefordparts
How much for HVAC controls and radios 2011 F350View attachment 187118
Hi,
the HVAC control head has been discontinued and I am not seeing any on the locator. For the radio, I am showing a few different numbers, all around the $750 range. (+$500 core charge) I would need the vin number to get the correct one.
thanks,
Sean
