JAustin
In March of 2024 I broke the crankshaft in my 6.6l Duramax motor in my 2015 Silverado. I ended up buying a long block motor from Choate Engineering in Bolivar, Tn., because I had a buddy that knew the owner, Cass Choate, and he spoke highly of him. I prefer to support the little guys anyway, so I went with his recommendation. Choate Engineering offers 3 motors for my truck, with the middle option offering a 5yr/100,000 mile warranty, versus a much lesser warranty if I went with the cheaper engine, so I went with the middle price and hired a reputable shop, HCS Auto Repair, to do the install. I will add here that the steps and processes Choate required to get the warranty during the installation, was insane. It required tons of pictures, videos, and special processes that took extra time that I paid for, but to get the warranty, we felt it was worth it. The installing shop told me they'd never seen such a long list of steps required by a manufacture and I had to pay $150/hr for the extra time they took to do this, but again, I felt it was worth it for the warranty.
Keep in mind, my truck is a daily driver that never gets worked. The heaviest load it's ever pulled is a 20’ equipment trailer that might weigh 2500 pounds hauling a 2200 pound UTV. For a diesel, that is not even breathing hard. It's creampuff that I keep extreme care of. I am anal with it's condition and cleanliness.
Fast forward now to January 25th, 2025, less than a year into my warranty and approx. 10,000 miles on the new Choate motor. I'm pulling my trailer and buggy when the over temp alarm went off. I look at the gauge and it's climbing to 250ish degrees. (Keep in mind, this is the coolant inside the motor, not the motor temp) This is also the first time the motor has ever overheated. I pull over and shut the truck off within 20 seconds. A friend that was with me, who is a good friend of Cass Choate, owner of Choate Engineering, calls him to ask what we should do. Cass had us check a few things and he suspected it might be a bad coolant reservoir cap. He told my buddy to tell me not to worry and that they’d take care of me since the motor was under warranty. So after the the truck cooled down, we carefully drove it to the next auto parts store and purchase a new reservoir cap, installed it, and finished driving home. When I got home, there was coolant blown out on the reservoir again, so I know it was something else.
Now I'm thinking the actual coolant reservoir itself is cracked, so I drove to Orielly’s and purchased a brand new reservoir kit for $225ish, and went back home and installed it. After I got it back up to temp, it started blowing coolant back out of the cap again. I got frustrated and went to bed.
The next day, I had my brother-in-law take a look at it, who is a master mechanic. He couldn’t find any leak in it other than the pressure build up that was forcing coolant out of the reservoir cap onto the engine and thought maybe it had a blown head gasket. So, he told me to take it back to the shop that installed the motor, HCS Automotive.
HCS mechanics ran some tests on it and concluded it was either the EGR cooler or a blown head gasket. My truck is “deleted”, so the EGR cooler isn’t even hooked up. So, they tore down to the heads and found that indeed, it was a blown head gasket. Both the shop manager and my service advisor told me they found loose head bolts when they removed my heads, as well as a couple other red flags. (I'm no mechanic and I can't recall exactly what the others were, so to be accurate I'll just leave it there) HCS also said the heat tabs, as shown in the pictures, looked brand new.
I had been in contact with the Choate warranty department during this time, and up to this point they’d told me they would only cover $50/hr for 20.6 book hours if it was a blown head gasket. I argued with them and told them that was a weak warranty because the shop rate alone on a diesel motor at HCS was $150/hr. After calling Cass Choate, he finally conceded that he'd offer $75/hr, but I would have to ship the heads back to Choate in Tennessee to be inspected, on my dime.
This is around 6 weeks into this process now and I have been without a truck this whole time. Choate had already shown zero sense of urgency in their responses and I was concerned this was going to drag out far too long if I continued on. The warranty department had sent me an email asking me to return the entire long block at one point, even. I was so frustrated with everything that I told HCS to forget the warranty, I’ll pay for it myself since Choate was offering to pay so little anyways, and just to have the heads inspected locally and put my motor back together. I then emailed Choate warranty department about my decision to bypass their substandard warranty.
The next day HCS notified me that the machine shop they use to work on these heads had ran tests that showed both heads were cracked. So, I notified Choate warranty department that we would in fact now be using the warranty after-all because the issue just got bigger. I told them I refused to pay freight on the heads as well, and they finally agreed to setup freight on their own dime.
When the heads got back to Choate, they did jump right on them, and after a couple of days, emailed me that they did not find any cracks in the heads whatsoever, but did confirm the head gasket was blown. So, they "o-ringed" the heads, replaced the head gaskets, and shipped the heads back to HCS.
Now this is concerning. I have a local reputable machine shop that swears both heads are cracked, and the manufacture that tells me they're not. Who do I believe? To be honest, I'm scared to death of this motor. The motor, installation, and now this future bill that I'm fixing to have to pay because of their weak warranty is going to put me around $26,000 deep on this. I can't afford to keep throwing money at it.
So, now I've decided I'm going to immediately put the truck up for sale and buy a new 2025 with the 6.6l gas motor. I'm done with diesel motors.
Yesterday I sent Choate warranty department an email asking how to go about getting reimbursed for the 20.6/hrs x $75/hr that totals $1,545 dollars. They responded with an email stating: We found no evidence of a manufacturer’s defect or cause of failure with your cylinder heads so there wouldn’t be any labor payout. No one from Choate has contacted the shop doing the work and I can't get a return phone call.
A blown head-gasket in less that 10,000 miles, and they are going to make me pay for it. Would not a blown head-gasket in itself be a factory issue? Especially 10,000 miles into a 5yr/100,000 warranty?
As of now, I have now contacted an attorney and will go broke over principle alone trying to recoup a minuscule $1,545 just to keep them honest.
I absolutely would not purchase from them again. Look up other customer reviews like I should have before I made a decision. There are far too many stories just like mine.
Mesa, AZ
I absolutely would not purchase from them again. Look up other customer reviews like I should have before I made a decision. There are far too many stories just like mine.View attachment 187887View attachment 187888View attachment 187889View attachment 187890View attachment 187891View attachment 187892
Are they running 2 different head gaskets in the motor? That seems very odd seeing as buying a gasket kit they typically match. Not a duramax tech by any means, but seeing as they’re different colors, that’s a big red flag there
JAustin
So I called out the same observation, but was told by Cass Choate they are different colors to keep from mixing them up. He said one has an oiler hole that if swapped, would cause a failure. I'll be honest, I am not a mechanic, but am good friends with several diesel mechanics that also asked the same question. Cass also says my 40hp tune very likely caused this issue which, I believe is a cop out. My response was that if a 40hp tune caused their engine rated for 500hp to fail, we have bigger issues. Honestly, I believe Choate has tried everything they can from the beginning to put this back on me, or the shop that installed the engine. HCS Auto, the installing shop, has multiple locations and are a premier shop in the NW Arkansa area for this type of work. They have been blown away by this issue and Choate's response to it.
JAustin
I would also add that the mechanic working on the engine found several head bolts loose when he removed the heads. I told this to Cass and he didn't even respond to it. To date, Choate has not attempted to contact the installing shop one time. I would think they would've wanted to talk to them to find out what they saw during the work on the engine. I am working to get a conference call setup between them next week. As it stands right now though, they are denying any warranty claim saying they found no factory defect when they inspected the heads. I mean, wouldn't the blown head gasket itself be a factory defect?
Mesa, AZ
That sounds like a cop out in the head gasket, seems like they may be mixing and matching gasket sets they’ve got laying around or something.
Several things do seem wrong about this.
First being the heads weren’t oringed originally? Seems like they’re cheaping out there, at least in the 6.0 world any engine built by a reputable builder for “aftermarket performance use” no matter how light the “performance” is comes with o ringed heads. In dealing with the guys at kill devil, it’s standard on their Cummins, 6.4, 6.0, and 7.3 engines, haven’t heard them talk much about duramax stuff, but I’d assume they would do those as well. Cheap insurance at that point.
Second, loose head bolts/studs is a red flag. Had a 6.4 a few years back built by a “reputable” shop somewhere in Texas who apparently deal mainly with gas stuff, but the head bolts felt like they did the first couple torqued, and none of the 90* turns. I didn’t actually check torque, but my gun typically hits a few times and then backs them out, and I could’ve probably done these with my 3/8, then after getting the heads off looked like they prepped the deck with a chainsaw. I’d recommend having the shop check the deck surface for flatness as well, may have blown on the under side of the gasket.
Third, having a machine shop who your shop trusts say there is an issue with the heads, and then choate saying there is no issue is another red flag.
Fourth, paying a bunch extra for a warranty that’s only going to cover $50 per hour is bs. Hell I charge more than that to work on stuff in my driveway, and I don’t have shop overhead I have to cover. Not sure what yalls typical tech pay is, but out here $50 an hour is going to barely cover an average diesel techs hourly rate. I’d say average around here is 40-50 per hour for a decent guy. I would however read their warranty stipulations very closely prior to getting an attorney involved, as it may cover their ass in some legalese I go cross eyed reading.
Fifth, I agree, a 40 hp tune should have no issue on that thing. Hell, stock 300k mile motors will live very happy at that power level, tranny? Maybe not, but motor for sure.
Finally, yes, a blown head gasket with their overheat tabs not being changed over, indicating you cooked the damn thing, is an assembly issue, parts failure, etc, which should be covered under warranty. If your heat tabs were popped or discolored, or whatever they do, then I could see them saying that it was a cooling system issue, or you burned the damn thing to the ground doing an hour long burnout, or some dumb shit like that, but without those tabs showing an issue, obviously it didn’t cook.
Good luck, I hope you get this resolved. This does seem to be commonplace from what I’ve heard from some others.
JAustin
I am an 18 year machinist with the majority of my time on CNC machines. I have extensive knowledge of machining processes. I asked the same question to Cass about why are we o-ringing the heads now. They face off the heads before assembly. While the head is on the machine getting faced, add one more endmill and o-ring it then. It may take another couple minutes per head, but if you're going to advertise your heads as "better than OEM", I would think it worth it.
I told them about the loose head bolts and didn't even get a response other than no fault found. Again, they haven't once tried contacting the shop doing the labor. It took me getting an attorney involved for them to even consider that. We have a conference call coming sometime this week.
At this point, my truck will be finished tomorrow. I am going to detail it really good and list it for sale hoping the engine really is now, as Choate says, "better than OEM". I'm driving it straight from the repair shop to my house where it will sit until sold. I'm too scared to drive it and can't wait to sell it.
Novapower62
New York
Don't buy from this overpriced company. I spent $27 k, installed engine and upper oil pan leaked like crazy. Not covered by warranty because it was a performance engine. Cost me an additional 3k to repair. No quality control whatsoever.
Don’t TRUST THIS COMPANY
JAustin
Last update. After asking Cass Choate numerous times to talk to HCS Auto, the installing shop, he finally agreed to a conference call. During the call, he asked no questions of them and just seemed very non-engaged. He was just doing it to appease me. After the call, I had a conversation with him about the loose head studs and he assured me he had photos of his people torquing them. My response to him was the fact remained, the head studs were loose and that was the root cause, and it was found and documented by the installing shop. He still denied any warranty and pretty much told me I was wasting my time. So, I sold the truck. I can't trust his engine and I won't have a truck I have no faith in. Last night my wife and I went and bought a new 2025 GMC Seirra with the 6.6l gas engine. After spending over 28k on a Choate engine, I have learned two valuable things. 1. Use reputable companies. 2. A warranty from Cass Choate isn't worth the paper it's written on. Buyer beware.
DEEZUZ
NO PUKESTERS
NWI
Can you link the Google profile of the place you are referring to..?
Im seeing absolutely horrid reviews. I don't know why anyone would proceed with seeing those ratings.
DEEZUZ
NO PUKESTERS
NWI
2 of them come up. I don't want to post them bc I don't want to post something that isn't related
JAustin
Not sure I know what you mean. The link I posted takes you to Choate Engineering Performance website.
DEEZUZ
NO PUKESTERS
NWI
When you type the business into Google search engine. Does the place you dealt with have a presence on Google..
Such as...
JAustin
I noticed today that Choate Facebook page deleted a lot of the negative reviews, including mine, which was 100% factual. Now they have a 90% recommendation rate which was quite a bit lower yesterday. I left my review yesterday after a buddy told me they had another negative review very similar to my experience. On some they choose to respond in a very smart alec "Cass Choate" tone. Instead of responding to mine, they chose just to delete it. Very interesting, but not surprising at all.
Bolivar, TN
Hi everyone,
Two things need to be noted from the photos. One is that the heat tabs are melted on one of the pictures, so we see that the engine got excessively hot. Hot enough to melt the heat tab, as seen in the photo that we're showing below.
Secondly, in this screenshot I'm posting, you, yourself, Mr. Austin, admitted that the engine ran hot, as seen in the screenshot of the text message you sent us.
But obviously, when a cylinder head gets excessively hot and melts the heat tab, it's going to cause distortion, or warpage, which will cause a head gasket to fail.
That's the reason why the warranty was denied. It was never said that a 40-horsepower tune would cause that. We did, however, mention that there was concern for injection timing. You can clearly see that the heat tab is melted, and per our warranty, and ANY other manufacturer, by the way, will tell you the exact same thing.
If the heat tabs are melted, then the engine has been run excessively hot. I know you initially said you did not see any high temps when you were driving the truck. Well, if there's no coolant in the cylinder head, or if there's no coolant around the temperature sensor because it's pushed that coolant out, you won't see the truck run hot because there's no way no conduit for it to convey the temperature back to the ECM.
As for your cylinder heads, we EXTENSIVELY examined/inspected your heads, checking the spots marked as potential cracks and checking anything else that could have been wrong with them. We vacuum tested them. We pressure tested them. They passed both the vacuum test and the pressure test. Neither of the heads were cracked. (Which I think is evident since you have since sold the truck to someone else and it's running strong.) We had our engineers run a straight edge across the heads in both directions, and they were not warped at all. We even had our team members take pictures and videos every step of the way so you could see exactly what they were seeing. They uploaded them all to a Google Drive folder (which I am happy to provide the link for here if requested), which was shared with you. Including videos of the vacuum test and pressure test, as well as close-up pictures of the spots that were marked as potential cracks. And we still agreed to go ahead and upgrade your heads for you. We cleaned them up and o-ringed them to give you added reliability/durability going forward.
I know you commented about us not o-ringing your heads in the first place, which was because you purchased our Daily Driver engine, not the Workhorse that includes o-ringed cylinder heads. Had you purchased a Workhorse, then it would have absolutely had o-ringed heads right out of the gate.
I'm not sure why you feel like you never were able to reach anybody, because we were in constant communication with you via email/phone calls the entire time your helpdesk ticket was open. You spoke on the phone to a team member and even to the owner, Cass Choate, multiple times, on several occasions. He even provided you with his personal cell phone number so you could always get in touch with him in case you needed anything. I hate that you feel like you had a negative experience with Choate Engineering Performance, but I'm not sure what more we could have done to please you, Mr. Austin. We hope this helps clear things up for anybody who had any concerns regarding this situation, and we wish you nothing but the best.
JAustin
Hey Cass, welcome to the convo! I don't know where your pictures of the heat tabs came from, but HCS sent pics of the tabs on my motor, that I provided to you, and they said the tabs looked brand new. I didn't say that, they did. I have emails I can dig up that clearly say that. What's in it for the shop to lie about something like that? Why would they do that? This is a large professional shop that has a very high review rating on Google and comes highly recommended by word of mouth. Not Jimbo down the street with a car lift. A real diesel mechanics shop. Who's right here, you or them?
HCS Auto sent my heads off to a local reputable machine shop to have my heads pressure tested. The same shop they've used for years. This same machine shop said my heads were failed their tests and were cracked. Why would they lie about that? What's in it for them? You say you tested them too and they showed fine. Who's right here, you or them?
I never said the motor didn't get hot. I clearly told you it did and that I shut it down, I think your screenshot shows "within 20 seconds". When BV called you on the side of the road, we told you the gauge showed hot and was pushing coolant out of the radiator cap. Remember that, Mr. Choate? This was right before you told me the motor had a warranty and that you'd "take care of me". I've never hid a thing from you and have been 100% honest this entire time.
When you asked BV to find out about the tune I was running, I told him then that you were going to use it to deny my warranty. He assured me you were a stand up guy, though, so against my better judgement, I told you it had a 40hp tune. Every diesel mechanic I know says that's not what caused this issue, but all of the sudden you jumped all over that, just like I knew you would.
Numerous times I'd reach out to you without a response. Numerous. I have emails that will show, and you know this, where I told you and Anna that I didn't get a response to my question. Sometimes it would take days to get a reply back. Emails, texts, whatever. Choate is terrible at communication. Why would I lie about that now? Well, wait. You are awful quick to come back with a smart-ass answer if there's one to be had, I'll give you that.
Lastly, other engine builders o-ring their heads on their "daily-driver" engines standard. Why you don't is beyond me. It's a simple process that really would make your engine "better than OEM". Had I purchased your work-horse engine, I'd just be out more money for sub-standard engine with a warranty not worth the paper it was printed on. Do better Cass. You wanna be the best you need to build the best. Your Google reviews clearly show you have a lot of pissed off customers who don't know each other, all singing the same tune. Not everyone is wrong, Cass. Own up to it and be a better person for your customers. We invest a lot of money when we buy your products.
Thankfully I paid out of my own pocket to make sure mine was fixed correctly and then I sold it. I can't have a truck with an engine I have no faith in.
BUYER BEWARE OF CHOATE DIESEL PERFORMANCE!
