E4od fluid level
DARTH_VATO
Aurora co
Changing the fluid in my transmission was wondering how many quarts it takes? Im just doing a drain and fill. I
And I do have the mag hytec pan which takes almost 8 more quarts. Any help would be appreciated.
Dv
Tom S
I do not know the answer to your question but if your truck has the stock convertor in it there will be a drain plug on it most likely so you can drain that as well. If you have not spotted it you are welcome to join the Colorado Diesel Truck Club as well.
Tom
Powerstroked162
On Da Juice
Wa. State
21 quarts total if I remember right.
You are safe to put 19 in and then start checking from there. As long as the converter is dry
DARTH_VATO
Aurora co
Tom
I have the banks converter in mine. Not sure about a drain plug on it? Kinda new to diesels honestly.
I will check out the club sounds fun I'm apart of a jeep club locally as well.
Mark Kovalsky
SE Florida, USA
You should be well overfilled by now. A stock pan will hold about 6-7 quarts when drained. If your pan holds an additional 8 you should have no more than 15 to add.
