Updated pics (Rigid LED light bar)
SSpeeDEMONSS
6mi from the beach, SoCal
They're worth it if you want some good light. I will post some pics of the dually or D2 that I believe will fit on the same spot as stock fogs. Don't wanna deal with it on my phone.
Garrett
jwlandry
S.W. Louisiana
How did you end up mounting it?
I went to Lowes, got me 3' of 3''x1/8'' plate and cut it the length of the fog light mounts. I used one hole at the top and the one at the bottom of the fog light mount on the bumper. Drilled some holes in the plate, put some paint on em and bolted them to the bumper. I also ordered the U cradle from Rigid with the light and I bolted that straight to the brackets i built, light mounts to the U cradle.
Holy chit, I gotta get one
Go for it D
how much are they again?! that's sweet
List for $700
wow, wish they wernt so damn expensive!
Its only money and you only live once.
Garrett
I really like it. It gets some attention for sure and throws damn good light.
That looks outstanding. I can see you've just cost me some money.
Thanks and Sorry:lookaround:
When I first went to look at the pictures on my phone I reloaded the page because I didn't think it loaded the picture right. Come to find out the stock fog sucks so bad the picture looks black! That light bar is incredible
Spatel23
Olive Branch, MS
did you buy the light bar mount from Rigid?
Do you mind posting a picture of the switch they include? Ill probably just run mine off an upfitter switch if I get one but Im curious as to what the switch looks like.
jwlandry
S.W. Louisiana
Yea Shone, it all came from rigid. I spoke with Skylar there. The switch is just a cheap button type rocker switch. I can get a pic later. You can use any switch you want though so up fitters would be perfect.
Mdub707
Mohawk NY
Jesus those are awesome. I can't get over how expensive they are though! I would love to have one of those....
sniper_101
rural SK
Choupique108 - Not to derail your thread here, but do you have pics of the running lights on your pinch weld below your doors?
Just curious to see how and what you used, looks good on your truck.
Love the light bar, looks so subtle. Can't wait to get my Rigid D2's!
I could use one of those....my lifted truck with no stock fogs(lariat and never had fogs?) is pretty damn terrible to see in at night. I am getting new 07 headlights and am contemplating the britebox as I do that manually sometimes, hold the switch back for extra light.
I could wire it into my brights and then if somebody was approaching I could shut that and my brights off in one motion.
F-117HWK
Chantilly, VA
Any reason why you cannot just wire it into the same switch as the stock fogs? That way you would just pull out on the headlight switch like stock to get the lightbar/Dually's to come on?
Did you use new wiring?
And thanks for the reply earlier, I forgot to check back.
