EGTs in hot tune.
Dieselboy.
Surrey B.C.
Was doing a bit of testing tonight writing a tune for drag racing. Im leaving the line at almost 1100* and by 80 MPH my gauge (1600*) is buried.
What do you guys normally see in egts by the end of the 1/4. I didnt even make it to the end in sense (judged by my MPH) and I was north of 1600*
Dieselboy.
Surrey B.C.
Didn't have a glance at my boost or backpressure gauge. I'm leaning towards a small boost leak maybe.
Last time I checked at 40-42lbs boost was 53-55lbs bp. I'm running a 1.10 a/r so its should be in check.
David N
Eastern NC
Hell mine pegs my 1600* gauge in a few seconds. Could be do to the fact that I have so much timing pulled though.
STROKIN N STYLE
GOM via NC
My gauge pegs going down the track, that's with A2W and a big boy water injection. It'll be alright, its only for 11 or less seconds at a time
Dieselboy.
Surrey B.C.
Hahah, thats awesome stroken. However I am a little short in the boost factory.
I will say though, this was the first time launching the truck at this power level. OMG LOL
Waxhaw, NC
you could pm hotrodtractor he would probaly have more assuring info. I rember reading somewhere that he post that he peged a 2000 degree gauge on ever pull with his red truck.
Dieselboy.
Surrey B.C.
Lol, ya but thats a competition calibre engine. Mines just a rebuilt stocker with a few hardparts thrown in her.
Obviously the boost leak will effect this, Im 6+ psi short ?
Junkie what did you see on your old engine WOT ? (Big sticks)
Hotrodtractor
Mingo, Ohio
I had 2200* EGT gauges in my truck - I would bury the manifold gauge and then some on every run that truck ever made - I made sure it was up to operating temp when I started, and gave her some cool down time. The problem is with prolonged high EGTs or with a lot of thermal shock loading. I can't stand here and say yes - you'll be fine with a 2200* EGT on every run - there is just too many variables - but I can pretty well tell you that I wouldn't even worry about only reaching 1600* EGTs by the end of the drag strip.
Powersmoker
Chesapeake, Va
:whs:
You don't want the heat to soak in.
I try not to think about Egts, my guage hasn't been hooked up for quite sometime. LOL
Dieselboy.
Surrey B.C.
Holy chit, really ?
Im concerned. My dads a diesel mech for hwy/marine. Anything over 1250* I hear about it lol.
Old hands
HRT, I saw 1600+ by 80ish MPH... This was just on a back road but holding it for the last bit at that degree is ok ? I figure I should reach over 100MPH in the 1/4. Not sure how many more seconds that equates to.
I will say I have confirmed a boost leak as in the summer I saw 40-41 psi WOT and now I cant exceed 34-35 psi.
Hotrodtractor
Mingo, Ohio
Holy chit, really ?
Old hands
Both highway and marine are often steady state constant loading situations - running them over 1250* for a prolonged period of time will typically result in high levels of heat soak and component failure. You are not operating under the same conditions during a drag race where you have a short period of WOT full load immediately followed by a period of cool down. Your entire run is what 13 seconds long? There is no heat soak to worry about with a run that length of time. The probe is in the exhaust gas stream and its true that it is what the temperatures of the gases are - but it is not allowed enough time to sufficiently heat up the major components to cause damage at 1600*. Now if you increase the temperature delta up to say above 2200* then you get some more heat transfer and depending on your run you might have something more to worry about - but that gets to still be a case by case basis because there is a big difference between just touching 2200* and holding it there for say 15 seconds.
Fix your boost issue - all of this is meaningless until you fix that.
