Peterbilt 359....
abbottfarms
Maine
It's not so much weather a wheel off a 379 will fit or not, Wheels on big rigs are not truck specific. What size are they? 22.5 or 24.5? What are they for wheels on it now? Dayton (spoke) hub pilot or stud pilot wheels?
jwlandry
S.W. Louisiana
thats right... Depends on if they are bud wheels, hub piolot, or unimounts... post a pic of the lug nuts and lugs on the wheels.
abbottfarms
Maine
images
Dayton wheel....
what the lug nut will look like if its Hub pilot
what the lug nuts will look like for on stud pilot wheels.
Hope this helps.
the 22.5 to 24.5 isn't so much a issue, as long as the wheels are the same. You can make anything work, however it's a lot more involved then just slapping a wheel on there.
Paul, pm me if you have any more questions.
Dave
01 blue 7.3
illinois
If you go from 22.5 to 24.5 you might not have to do any thing. The lug pattern is the same. U might have to calibrate your speedometer.
abbottfarms
Maine
You will not have to do anything to swap 22.5 to 24.5 you are correct. The speedo on a 359 is probably off anyways...I would not mess with it, only be off by 2 or 3 mph anyways. I have swapped rubber size more then once and never did anything with the speedo.
01 blue 7.3
illinois
And don't forget if its stud pilot. Either the nut or the stud that's square on the end is left handed thread. I can't remember.
ParkerFly
McMinnville, TN
The stud should have an L or R stamped in the end of it to tell you what the thread is. In later years they quit doing that half left handed crap and went to all right handed, but I'm not sure what year that was. I'm guessing late 70's or 80's since I've seen several mid-70's model trucks that had left and right hand studs/nuts on one side.
What year 359 is it?
abbottfarms
Maine
This is false it depends on the axels in the truck the lighter axels are hub pilot! We had a 97 that was stud pilot For
The factory
Not really lighter or heavier axles, so much as how the truck was spec'd from the factory...I have a 97 with eaton 46 rears on hub pilot.
