Not too bad for a stock HPOP... :)
dirtboy25
Ft. Scott, Kansas
As far as I know this is the stock HPOP with over 191k on the clock. Pics were taken on a 60-90mph run on the highway today. When these were snapped I was running between 85-90mph.
All stock engine with mild tunes.
Duty cycle is on top, pressure is on bottom.
HaysKSFirefighter
Valley Center, KS
It must be a Christmas miracle! LOL I've never seen a stock pump with those miles hold 3k psi Sweet little baby Jesus in his tuxedo must have blessed that pump from the factory :priest:
dirtboy25
Ft. Scott, Kansas
Is that at WOT.
Yes it is... I took the pics on a 60-90mph run. I took the pics one after the other on the same run. If you look at the tach in the pics you can see the rpm's rising. The order of the pics aren't right but It goes top, bottom, middle.
At that rpm in OD I believe the mph should be around 85mph.
sniper_101
rural SK
Not too shabby! What injectors?
180k on mine with 160's mine will hold 29xx @ 36% IRP. Pretty pleased myself.
