01platinum
Ok just installed my FP gauge and started the truck. The gauge zeroed out then came up to 50psi. After I started the truck the gauge stayed there for 3-5 seconds then moved to 60psi and slowly moved to about 64psi. Now is this normal or should it go straight to 64psi? Also what is a good PSI to run on the fuel system? I thought it was 68-70 but can't remember. I have a airdog II and a regulated return fuel system.
Sent from my SPH-D710 using Tapatalk
