Cppr Busa
Illinois
I need a price on a auxiliary audio jack, the plastic cover and wire to run to the back of the radio.(opposite dash 4x4 switch under the radio on passenger side.) For a 2008 ford super duty. Thanks for your time!
sunrisefordparts
plastic bezel list $45.40 sell $34.05
head phone jack list $85.04 sell $63.78
as for wiring no actual pigtail/jumper to radio, serviced in complete dash harness
BFT
southern cali
2008 super duty 6.4 td
price on up pipe to EGR catalyst gasket (metal)
both up pipe to turbo gaskets with bolts
the gasket that is used to press the 2 turbos together
2 large o rings for turbo drain
2 small o rings for turbo drain
sunrisefordparts
see attachment
  • Q257226.pdf
3brorce
price on exhaust fitting on pressure sensor. not the three EGT sensors. I need just the fitting that goes into exhaust. The fitting that the rubber hose slides over.
3brorce
I think the part number for this is 9j454
