Arisley
Instead of the .50 mod on the UVCH, I just put a dab of epoxy on each corner of the UVCH. If I ever have to replace them, I can cut the epoxy with a Dremel.
definitely do exh manifold gaskets...anitsieze on new bolts, and possibly a Melling LPOil pump since access will never be easier...
Awesome, that's a list I can sink my teeth into.
I'm assuming a fuel bowl delete is not for me since I live in the cold cleveland area?
What's this mean: "INJECTOR CUPS, so you can use ELC!!!"
Thanks!
Thanks!
Really?? I have seen several failed exhaust manifold gaskets - but only ONE manifold that leaked without them...![]()
As I think about it........ I probably have everything you need to go to a late-'99 turbo set-up if you are interested. Exhaust manifold, stock uppies, EBPV-deleted pedestal, plenums and even a van turbo. :naughty:
Can anyone comment on the benefits/drawbacks of doing this swap?
Benefits: More air into the engine.
Drawbacks: Money and time.
Isn't the turbo on the E99 bigger?
Are you saying to install the manifolds w/o gaskets??
- ceramic coat exhaust manifolds, up-pipes and turbo exhaust housing w/Turbo X (http://www.techlinecoatings.com/hi-performance/bs-exhaust-system-coatings.html)
Can you put that stuff on rust? manifolds, uppies and turbo are all a little rusty.
