driverside window switch no worky?
TRUBBS
Balls Deep
so here is the deal, had the problem for a while and just never really had the time or motavation to dig into fixing it.
rolled the window up to wash the truck, finished washing it & went inside to get some lunch, came back out and the driver side window switch wont work (wont roll down driver or passenger side window) but i can walk to the passenger side and the window will roll down.
driver side will roll up and down if i pull the switcher out and run a hotwire to the up/down pole.
so that would seam like a bad switch right? pulled one out of my buddies e99 (only difference between mine/his is that he has power mirors both are e99's{maybe that could be an issue?} ) still nothing.
ok so maybe the gem got wet?-swapped the gem out of his e99 (well swapped entire fusebox/gem bundle{maybe that could be an issue?})
is their maybe a fuse or something that ive blown that im not aware of?
what else could this issuse be caused by?
ive heard that maybe the wire bundle in the door might be shorted from open/closing but how can i get the wires out to check them?
PStroked444
OR
Probably the cummins infecting the ford :slap: Sorry had to...:doh: Dirty contact I bet. Take it apart and use a small file or cut down a fingernail file to clean the contacts. Had to do it on my wifes focus. Good luck:toast:
TRUBBS
Balls Deep
Lol I have been waiting for that comment... Haha
Thanks for the idea, if it works I'll Probacly have to reach through the computer and e-choke your @$$ haha
TRUBBS
Balls Deep
well got some good news and some bad news,
good news- i wont be reaching through the computer to e-choke you
bad news- i still dont have power winders :( :fustrate:
help me out guys!
Atsah
Maine
Pull the switch pod out and move the connectors/wires, unplug and plug them back in and see if you can get them work.. That's how I narrowed it down to the switch on my friends truck..
TRUBBS
Balls Deep
i pulled it, wiggled them,tapped them, cleaned the inside "sleve" for the wire prong. crused at it, called it dirty names, called it sweet names. nothing works. but for some stupid reason i can "hotwire" it up and down. but yet swapping the switch from my buddies e99 with power mirrors didnt fix it? ugh lol
Atsah
Maine
Is the E99 switch the same?
Atsah
Maine
Can you take the pod from the passenger door and put the plug in at the drivers door just to see if it works? Just a thought, IDK if you can or not..
TRUBBS
Balls Deep
both trucks are e99's built the same month to, only differnce is that his has power mirrors and mine does not.
hmm not sure it i could switch them like that ill have to check and see...
EDIT- just went and checked and you can NOT swap driver/passanger switcher
TRUBBS
Balls Deep
How could I check the wire bundle in the door? Can't seam to get the rubber boot out of the way to look for a bad/broken wire..
TRUBBS
Balls Deep
ended up finally finding the problem. it was a bad wire in the door bundle, fixed it and bam! windows work again :)
