Quick trans question
psdguy95
Effingham, IL
Couple more quick questions... My trans has 226k on it and I have no idea when the fluid was last changed... Should I even bother to do it? Where do you guys get your filters for it from? Ford or the local parts store? And what fluid should I use... Ford fluid it can I run amsoil?
neverkickn
AR
Hey Mark, how do you feel about running a synthetic fluid like shaffers in a stock trans behind a modified engine?
Pstroke96
Connecticut
i changed my fluid at about 210k i dont know when it was done before but anyways i dropped the pan and drained the converter it ended up taking about 4 gallons and 3 qts i bought a whole case and had a whole gallon plus a little left over i was told that switching to syn from conventional isnt really recomended because the additives in the two can attack each other and turn the fluid to garbage much sooner than it would normally. regular drain interval on atf is about 30,000-40,000 i put valvoline max life in mine, its been like 15k and all seems well with it
