Leaking fill tube
Dieselboy.
Surrey B.C.
My fill tube on my trans leaks, the actual 6" stub neck thats pressed into the casing.
Is there any aftermarket solution to this. No O ring to replace and I doubt a replacement will fit any better...
Thinking of cleaning it and dumping a bead of INTL grey silicone around it.
But have a feeling thats just a bandaid on a bullet wound.
Dieselboy.
Surrey B.C.
I did some searching last night, the only one that came up was on FTE and he said he went to Ford and they only list an o ring for the long filler tube that sticks into it.. Mine is leaking where it inserts into the Transmission casing.
kip4234
the oring is on the lower going to the casing the upper just is a slip fit
