Help with codes
SDstroker
SE, SD
First off I am fighting a rough idle/ slight miss.
Ran a buzz test, 2 injector sounds a little weaker(#2&#4) then the rest and got a P1668. Immediately cleared and ran test again, all injectors sounded the same and passed.
Next I ran a CCT and got a p0272 for cylinder #4.
Also had a P1670 stored.
Any ideas on where to start? I ohm'd the injectors and they all come out to around 3.6.
SDstroker
SE, SD
I read some stuff and I am going to double check the UVCH connections. IDM either works or it doesnt right?
I just thought it was weird that 2 injectors sounded weak on the buzz test and the next test they all sounded the same.
ToMang07
Mainah!
I would say a UVCH is a good place to start. Be sure to check for burnt pins, and insert a trimmed quarter if it's good!
ToMang07
Mainah!
SDstroker
SE, SD
I haven't had much time but I crawled up and the outside connectors seemed fine. Hopefully this weekend I can get the valve covers off and check inside connections.
For what ever reason I unplugged the ICP sensor and the truck idled smoother and was a lot quieter. No oil in the sensor connector. Plugged it in and went back to a choppy loud idle. Sensor bad?
